I was looking to upgrade to Starter plan from Hobby Plan, can I create more than one service in free tier/plan with Starter? And it says “3 Seats” in the plan description, what does “Seats” imply? And does “Concurrent builds” mean apps building/deploying at the same time?
Hi @Sarthak_Agarwal,
Happy to help answer your questions.
The free tier lets you deploy one Free Instance. The Free Instance is available to everyone whether you have a Hobby, Starter, or Startup plan.
Upgrading to the Starter and Startup plans lets you deploy more services with our paid resources. The eNano Instance is the entry point, priced at $1.61 to run for the entire month. For more pricing details, check out our pricing page.
Seats refer to the number of people in an Organization. 3 seats means you can invite 2 other teammates to join your Organization on the Starter plan.
Concurrent builds are apps building at the same time.
Let me know if this information helps answer your questions.
Cheers,
Alisdair
