Hello
I connected my github repository where I have my code in subfolder api-cb.
How to tell buildpack to work from there?
I set up PROJECT_PATH environment variable to api-cb but looks like it’s not working.
Hey,
Inside the buildpack builder configuration, you need to set “Work directory” to ./api-cb
Hope it helps ![]()
Thank you, this worked.
But now looks like Go 1.22 is not supported and I can’t simply go to 1.21 because of https://huma.rocks/ REST API framework I’m using…
Fixed it with Docker, thank you for help.
