Build pack error
Hello. I’ve got this messages during deploy my app.
could you guide how to handle it?
Thanks.
Build ready to start ▶️
15:56:58.081
Cloning github.com/superukie/chatgpt.git branch master into /workspace
15:56:58.081
Cloning into '/workspace'...
15:56:59.050
Previous image with name "registry01.prod.koyeb.com/k-ad4e4b7e-5761-4b46-a0b7-e6e3e154ea79/45795abc-a2d0-4f8a-bc81-01b2709f7c4d:latest" not found
15:57:00.849
ERROR: No buildpack groups passed detection.
15:57:00.849
ERROR: Please check that you are running against the correct path.
15:57:00.849
ERROR: failed to detect: no buildpacks participating
15:57:00.849
exit status 20
15:57:02.849
Build failed ❌
Hi there,
Just looked at your repository, and I noticed that your code is in a subdirectory. Currently, we need your code to be in the root folder of the repository to build it. I also noticed that your application doesn’t contain a requirements.txt or setup.py which is also needed to indicate to Koyeb the dependencies to install to properly run your app.
Regarding subdirectory support, you can vote for the feature here so you will be notified once available.
Let me know if you have any additional questions.
