Unannounced Quota: `Your project has exceeded the written data quota...`
Hi, Dear Koyeb Crew,
I started to experiment with Koyeb, and I deployed an app on Docker+PostgreSQL, and after a short while I’m getting this error:
Connecting to database...
Error: Connecting to database: error returned from database: Your project has exceeded the written data quota. Upgrade your plan to increase limits.
Application exited with code 1. This usually indicates an application failure. Check that the command used to launch your application is correct.
However, my quota indicators show these data:
Compute time: 0 h / 5 h | Used storage: 30 MiB / 1GiB
What is the current quota for write operations on free DB tier, how do I monitor it, and when will it reset? Or is this a bug?
I have checked the docs, but found only the already mentioned quotas…
I’ve got the same issue. Very frustrated with Koyeb’s greed recently. The limit is not mentioned anywhere, but suddenly my perfectly working app is broken because of this ninja update
Yeah, I hope this is just a bug.
As a new user, I just deployrd a container of windmill.dev + a DB for it, and I was paying around in its UI, for max ½ hr.
So nothing intensive happened on the DB. So this limit must be quite aggressive.
