Just another short update. For comparison I also tried Neon DB for the database.
If I understand correctly, free plan on Koyeb includes 1 GB of data. We triggered data transfer limits after about 3 days on a very idle running system.
I tried to reproduce it on Neon. After about 7 days I have about 120 MB of data transfer.
Could there be an issue regarding the way data transfer is counted?
Or does Koyeb aggregate different data.
Could you tell us more about the difference between your two configurations/settings?
From our internal investigation, what is reported by Neon matches what is stored in our database. If you’ll allow it, I could share some screenshots (with sensible information redacted) to eliminate this lead with your investigation.
What I did was to use the koyeb service that I had already deployed. Then switch it over to a Neon database. So same version of the software, same behaviour expected
So maybe my problem is that I do not understand the koyeb data transfer limit.
Please feel free to share some screenshots of the data you collected.
