Unable to deploy
I had a web service up and running for a month. Made few changes, then new deployment didn’t work. Deleted the web service and recreated and still got the same error. I thought something is wrong (though works perfectly fine on two local dev), deleted the app and went to basic app.
The deployment of this simple app itself is giving the same error.
Can someone from Koyeb check below error?
Instance is starting. Propagating network configuration...
Network configuration propagated
Instance is stopping
Hi @blah,
in which region have you tested it? I’ve just tried and everything worked.
Washington DC. I switched to Frankfurt and it works.
Same issue as the other user reported Cannot deploy after code changes - #3 by Jem
I can switch to Washington, if it is working now
Switched to Washington DC. same error An error occurred while deploying your application
Instance created. Preparing to start…
Instance is starting. Propagating network configuration…
Instance stopped
Can you share the deployment id of failed try? I’ve tried in all regions and it worked ok.
Sharing the url is ok too.
deploymentId=3aeb8201-3858-49a4-9f72-1e03354c4dae
sorry for a late answer. I’m not sure why it happend for a given deployment. The only thing I see in the logs is that health check failed. It could be caused by our internal issue. Is it still happening?
