I got stuck on synchronizing repositories while importing project
Hi there,
Can you let me know if you are still facing the issue? Looking at your account everything is looking fine on my side.
Thanks
yes iām still stuck on this loop
Can you try to uninstall/reinstall the GitHub app and let me know if it solves the issue?
Thanks
reinstalling the github app works! thank you!
