Hello, I deploy msql:latest on micro where daploy is healthy but I can’ connect via mysqlworkbench. Password is set, ports set on 3306/tcp.
Runtime logs show that server is shutdown.
Is somebody use mysql working correctly on koyeb platform?
Could somebody help how to fix my problem?
Regards rzi
below runtime logs:
2022-11-21 19:27:00+00:00 [Note] [Entrypoint]: Temporary server stopped
instance-a2f236ee
stdout
instance-a2f236ee
stdout
2022-11-21 19:27:00+00:00 [Note] [Entrypoint]: MySQL init process done. Ready for start up.
instance-a2f236ee
stdout
instance-a2f236ee
stderr
2022-11-21T19:27:00.601330Z 0 [Warning] [MY-011068] [Server] The syntax '--skip-host-cache' is deprecated and will be removed in a future release. Please use SET GLOBAL host_cache_size=0 instead.
instance-a2f236ee
stderr
2022-11-21T19:27:00.604961Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.31) starting as process 1
instance-a2f236ee
stderr
2022-11-21T19:27:00.615942Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
instance-a2f236ee
stderr
2022-11-21T19:27:00.863487Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
instance-a2f236ee
stderr
2022-11-21T19:27:01.122405Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
instance-a2f236ee
stderr
2022-11-21T19:27:01.122578Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
instance-a2f236ee
stderr
2022-11-21T19:27:01.123378Z 0 [Warning] [MY-011810] [Server] Insecure configuration for --pid-file: Location '/var/run/mysqld' in the path is accessible to all OS users. Consider choosing a different directory.
instance-a2f236ee
stderr
2022-11-21T19:27:01.143550Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Bind-address: '::' port: 33060, socket: /var/run/mysqld/mysqlx.sock
instance-a2f236ee
stderr
2022-11-21T19:27:01.143870Z 0 [System] [MY-010931] [Server] /usr/sbin/mysqld: ready for connections. Version: '8.0.31' socket: '/var/run/mysqld/mysqld.sock' port: 3306 MySQL Community Server - GPL.
instance-1bd798f7
stderr
2022-11-21T19:27:29.325466Z 0 [System] [MY-013172] [Server] Received SHUTDOWN from user <via user signal>. Shutting down mysqld (Version: 8.0.31).
instance-1bd798f7
stderr
2022-11-21T19:27:30.007819Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.31) MySQL Community Server - GPL.
