Issues with deployment for the last few hours (Suspecting issue at Koyeb)
Message
Event
2024-05-16 22:00:46.586
ecfccbb0
`Instance created. Preparing to start...`
Event
2024-05-16 22:01:04.917
ecfccbb0
`Network configuration propagated`
Event
ecfccbb0
`Instance is starting. Propagating network configuration...`
Log
2024-05-16 22:08:44.857
stdout
ecfccbb0
Log
stdout
ecfccbb0
`> duned@0.0.0 start`
Log
stdout
ecfccbb0
`> serve -s dist -l 8000`
Log
stdout
ecfccbb0
Log
2024-05-16 22:08:45.609
stdout
ecfccbb0
` INFO  Accepting connections at http://localhost:8000`
Event
2024-05-16 22:12:52.086
ecfccbb0
`Instance is stopping`
Event
2024-05-16 22:15:26.071
ecfccbb0
`Instance stopped`
No error logs of what is happening and instance is just failing, seems to be an issue at your side as nothing has changed on ours.
Hi @InfamyStudio
Sorry to hear that! It seems that the health checks on your apps are failing (and we are not properly displaying this). We are going to fix this. In the meanwhile, can you check what is preventing the health checks to succeed?
Hi there, the service seems to have come back. Seemed to be an issue with the Frankfurt region, but I would recommend you guys invest some time into better health checks and error logging for customers. As you can see all we were getting was instance started, instance stopped. If there is a failure at the host this needs to be passed onto us and maybe put in procedures to auto switch to another region as a temp measure to compensate downtime of new deployments.
@Leonardo_Barcaroli I have the same problem, can you help me?
