I cannot find a way to have access to logs from my Koyeb Postgresql instance. I have a query that works on any other db but fails here and I cannot investigate…
Here is the output of some logs related queries which shows the logs cannot easily be accessed by the user:
SHOW log_destination;
SHOW logging_collector;
SHOW log_directory;
SHOW log_filename;
log_destination
stderr
(1 row)
logging_collector
off
(1 row)
log_directory
log
(1 row)
log_filename
postgresql-%Y-%m-%d_%H%M%S.log
(1 row)
Any help on this one ?
The issue I encounter is the following:
(Background on this error at: https://sqlalche.me/e/20/e3q8)
Traceback (most recent call last):
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1964, in _exec_single_context
self.dialect.do_execute(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/default.py", line 942, in do_execute
cursor.execute(statement, parameters)
psycopg2.OperationalError: SSL connection has been closed unexpectedly
While the queries work perfectly well when connected through psql, it does not work when the session is idle for too long on my Koyeb Small Web instance.
I cannot debug it with PostgreSQL which is a real pain in the ass.
