Major project oversight
I have two Organisations, for the sole purpose of different billing accounts, issue is I need to use the same GitHub organisation. And the system will not allow this. This needs urgently fixing. I need to be able to select any authorised GitHub account connected to my overall account to then select it to any organisation.
Hey,
Could you clarify your issue?
We have a 1:1 binding with the GitHub organization. Similarly, you can create multiple Koyeb organizations and have different billing accounts.
Best,
Bastien
So I have an organisation currently linked to our main GitHub account. This GitHub account contains many of our companies products and projects that a few are hosted through organisation 1. We recently built an application for a client and we want to host through their billing details. I now create a new organisation in koyeb and then I attempt to find our repository and it’s not there. This 1:1 binding of GitHub account to org is the major problem.
This needs to be a lot more flexible. Current 1:1 is pointless as it allows for no real expansion, you are currently forcing me to start putting everything within the same organisation, same billing details, that are all on the same private network, with shared domains and secrets. That is a problem for me and makes koyeb not a suitable option to host our work and our clients.
Thanks for clarifying!
So, if I understand correctly, you would like the ability to link the same github organization to multiple koyeb organizations?
You don’t need to have access to multiple github organization from one single koyeb organization right?
Yes exactly that, It is very restrictive in its current form the platform and makes work very difficult. Currently I cannot manage client projects on separate billing because of this restriction. This would be a great change and would allow for a lot more freedom. I would hope you guys can go back to the drawing table with this and come up with a much more flexible all round solution. I do think you should investigate the idea of multiple GitHub accounts/orgs as well as what I have already mentioned.
The more freedom of control to manage my internal organisations with where we store client code will be a big help!
