Hi, seems like there’s an incorrect constraint
Hi, your volume and your instance disk are 2 different disks.
If you attach a volume to your instance, you will be able to add persistent storage to your service (between 1 and 10 GBs). The data stored on your instance disk is not persisted between deployments.
In your scenario, you can have a nano instance with a 10 GBs volume attached to it.
