Egress monitoring
Hiya,
I’m coming over from a competitor service whose egress costs have me running for the hills, even for my meager single hobbiest app deployment.
While i understand the limits/cost (100GB egress, 0.01 USD for each GB over?) i don’t seem to have anywhere to view what egress/networking ive used so far. It’s not in the billing/usage view and not in the app or service metrics view.
I’d appreciate if you can point me at the right direction.
Hey!
You can estimate how much data is getting out of your service to the Internet using the Metrics tab in the Service view.
So far, we’re not billing egress, so you are covered. If your usage is excessive, we will privately contact you and/or pre-emptively shutdown your service.
Hope this helped!
I can only seem to see CPU and Memory usage in that view. Possibly due to only having deployed recently/having very low egress so far?
Oh! You have deployed a worker. We do not. display egress for workers, I think that’s a miss on our end.
I will check with the team if we can enable egress metrics for workers :slightly_smiling_face:
Ew, it is intended actually. This is a limitation of this service type.
Sorry about this limitation -worry not about the egress fees, as long as it is not abusive, your service will not be paused. In any way, you will not be billed for egress.
Thank you for the update, That’s good to know :]
