Telegram bot on java
Hi there
I deployed telegram bot wrotten on java and getting status unhealthy. In console no errors. Bot works fine first 15m then his stop with status failed and message “Deployment was unable to start. Deployment took more than 15m0s to reach an healthy state”.
Any ideas what it could be?
Thanks
When a service starts, Koyeb will check that all the ports configured are listening. So if one of the ports is not listening 15 minutes after your service started, it will be considered unhealthy and will be stopped.
To fix the issue, you just have to listen to the ports you configured on your service (the ports can be configured from the control panel, on the service’s settings page, in the “Advanced” > “Exposing your service” section).
Hope that helps!
