My apps stop running After some time
Hey there!
Did you look at your runtime logs to see what is going on? You can access them from your Service page under Runtime Logs.
You can also check our troubleshooting documentation: Troubleshooting Deployments - Koyeb.
Let me know if you’re still facing an issue, I can help!
Make sure something is running on the port you specified, like a simple express server for example. Otherwise your app will be considered ‘Unhealthy’ and shut down after 15m.
Exactly, I provided some more context here if it’s a worker:
It might also be a failure of the app to start which can be seen from the runtime logs.
