i want to type this
apt-get update
apt-get install net-tools
ifconfig
but i have error:(
Hi,
You must be using a root user to use these commands. You’ve built your service using Buildpack builder which does not provide a root user.
I would recommend using a Dockerfile and setting USER root in it.
Then, change your builder type to Dockerfile and you will be able to run these commands.
thanks for your answer
so i tried and :
Build ready to start ![]()
Cloning GitHub - swk3087/server commit sha 52ac1bf7619d8482e840684a9c3c178441d2f4c3 into /builder/workspace
Initialized empty Git repository in /builder/workspace/.git/
From GitHub - swk3087/server
You need to write this Dockerfile.
Here are guidelines for it. Writing a Dockerfile | Docker Docs
thanks i I did it.
