Is it possible to use the pg_cron extension on PostgreSQL at Koyeb?
I would like to use something like CRON for running some SQL functions. Is pg_cron available with PostgreSQL at Koyeb? If so could you point me in the direction of which documentation I can follow to get it going please? If not, which alternatives are available?
Thanks in advance.
Hi @Mark_Howell,
Unfortunately, pg_cron is not available :frowning:
Hi @Lukasz_Oles
Thanks for the confirmation. What alternatives do you have available that can manage scheduled execution of PostgreSQL functions?
Hi @Lukasz_Oles
I think I will go down the route of using Github Actions to create a cron style schedule, which will then trigger the job i need to run via the koyeb api service.
Something that others may have already done.
Kind regards,
Mark
Please let us know if it worked for you!
As mentioned in the above post, I have managed to trigger a PostgreSQL function via REST a few times per hour by creating a Github Action with the following included in the YAML:
schedule:
  • cron: ‘*/15 * * * *’
This works without authentication. I just need to tidy that bit once your new functionality for authenticated endpoints is available.
