Hy, It’s my first time trying to deploy a project, and I make a project in Laravel using sail.
Now I’m trying to run npm run dev to build de content of css em js, but by the console i don’t have the installation to run
Hi Thales,
Thank you for your message. Unfortunately it is not possible at the moment and since you posted the same question on the support channel, I’ve already added your vote to this feedback:
As a workaround, you can deploy pre-built containers.
Regards,
Sebastian
