Deploy static React website
my team has a frontend in React that talks to backend API in Flask. I deployed the backend successfully but I cannot deploy the frontend. It build successfully but then fails with “no run command”. I tried overriding run command by faking the run command such as echo “No command needed” which still didn’t work as it was stuck at
Instance is starting. Propagating network configuration...
Network configuration propagated
No command needed
No command needed
Application exited with code 0
Instance stopped
No command needed
No command needed
Instance stopped
How can I deploy a static page?
Thanks
Hello!
What about creating a Dockerfile, and using nginx?
To do so, follow these steps:
  1. Create a Dockerfile:
FROM nginx
COPY . /usr/share/nginx/html
  1. Create a Koyeb service. Select the docker builder, and expose the port 80.
  2. tadam! it should work
yes that is what I ended up doing. I thought there has to be a simpler solution.
