ReactJS Apps Not Deploying
I am attempting to deploy React to Koyeb via Github, but for whatever reason I am always greeted with a blank screen when visiting the app. This is despite the fact that the build is supposedly healthy and successfully deployed according to Koyeb’s monitoring.
Even a basic React app with no modification to the generic “successfully deployed” screen doesn’t work.
Would anyone be able to offer some troubleshooting tips?
Thank you!
Hello @Smithy, could you share your service ID?
Thanks for your reply.
I ended up (accidentally) solving the issue.
On a whim I decided to create an instance of the app with more cpu, memory, and hard disk space and it seemed to fix the issue. I retested multiple times using more and less powerful server configurations. I was able to get consistent functionality only with the more powerful configurations. The less powerful ones always failed.
Chalk it up to a rookie mistake. For anyone else in the future running into this kind of issue, try giving React more resources!
Thank you for sharing the solution!
This topic was automatically closed 14 days after the last reply. New replies are no longer allowed.
