How can I distribute a Github subtree directory?
hello.
I am using koyeb and github linkage.
In order to build and distribute the project when integrating with GitHub, all project configuration files are located in the workspace.
root repository
|-Procfile
|-build.gradle
|-system.properties
|-etc
But I would like to place the files in the Github branch like so:
root repository
|-backend
|-frontend
So, I want to put Procfile, builde.gradle, etc. inside the backend directory.
can i know what to do?
Hey @Lee_June_Hee,
Are you looking to deploy code from sub-directories? Currently, we need your code to be in the root folder of the repository to build it.
There is a feature request for subdirectory support, you can vote for it here and you will be notified once available.
Does this answer your question?
Thank you. @alisdair
Thank you for your reply.
I voted as you said.
I hope to be able to help as soon as possible.
thank you
