Help in creating domain
I am currently on starter plan. I was able to publish flask application and it is working fine. Now i am planning to create a custom domain. But upon creation an error always occur below is the error
Invalid configuration
CNAME record for this domain is not correctly configured or propagated. Verify the CNAME entry configuration and try to refresh your domain status.
How to address this?
Thanks a lot
Aze
Hi @Anthony_Estrada,
It seems that you do not have a CNAME entry for these domains.
You need to check with your provider on how to create a CNAME entry for your domain.
