i cannot redeploy
Hi,
So you had 2 healthy instances while using the Free instance? It seems the deployment ended up in error. Is this correct?
Thanks.
yes, error when redeploy
We are not finding the service at fault. Can you give us the service id and/or your organization name?
07ff7f09-d356-e197-8d65-e2470150e6a0
stop this pls.
I am sorry, what is this id? Cannot find anything matching it.
Could you give me the organization name?
oke,
jackorg
The issue is fixed. We have faced unexpected issues stopping the instance. This led this strange behavior. It is now resolved.
