This is not the first time when my healthy working webservice interrupts unexpectedly and take the website down. (b6d9992b).
It fails silently until I deploy again the exact same commit (without build).
What do you mean by it? How does it fail? Does it stop responding?
As for the screenshot, it’s a known console issue that we are working on.
The website goes down .. 500 error no response. Then when I login to the console I see that there’s no web instance attached to my deployment. Then I will have to redeployment manually to restore my service
After 1h of inactivity, we put an instance to sleep. When a new request comes, we wake up the instance. If it takes a long time for an instance to start, you can see a 500 error.
I’ve checked the logs, and I don’t see any issue with your app.
That’s because I redeployed it.
It’s happening again. To be fair, after evaluating Koyeb I don’t think it’s reliable. Sorry but that’s not a great user experience.
It’s been 24 hours since the last attempt to load the service. I left it down for you to prove that Koyeb failed it not hibernation.
Hey @M_Y
We are working on the fix. It will be released today. I’m really sorry that it’s affecting you.
