I have a couple of applications that I used to deploy from a set of personnally-owned private github repositories.
I recently changed the repository ownership to an organization I own, and I now want to my apps to use these as the source.
I have the koyeb gh app installed on my personal account, but the repos do not show in the list for deployment sources now that they are owned by my org.
I tried installing Koyeb on my org from the gh app marketplace but I do not see the app in the list.
How can I access the new org’s repo from koyeb ?
I managed to fix on my side, but foer the record the trouble was with
Installing the Koyeb app in the GitHub organization of your choice
The issue was:
I migrated my repos from personal private to org private.
I couldn’t grant my koyeb account access to my org private repos in addition to perso repos
As a result, my org private repos remain invisible from my koyeb account
What I did:
uninstall koyeb app from personal gh.
Back to koyeb, click “install on gh”
Picked my org account for the install
If I understand correctly there is no way currently to access my perso AND org’s private repo from the same koyeb eg. have the same koyeb space installed on 2 separate gh workspaces. Correct ?
