Changing the system timezone
I am looking for a way to change the system timezone of koyeb instance, as it logs everything as if they happened 3 hours before Turkey’s GMT+3 timezone. Thanks.
Hey @aozkinay :wave:
The timezone of all machines is by default in UTC.
You should be able to use the TZ environment variable to change it, but it’s usually a good practice to keep it in UTC.
