I want to start of by saying I love Koyeb its an amazing product. I wanted to know if I can deploy my application directly from the IDE I previously used Deta space and I loved it because how fast I could deploy via CLI I wanted to know if Koyeb can do the same?
I came across this page but I wanted to ask if it really does skip GitHub and docker and directly uploads or still require Github if so you have already made my day.
Secondly, in case you have made my day I saw this example “koyeb deploy . my-app/my-service” so just for general understanding if my app name was YouTube the command would be “koyeb deploy . Youtube/my-service”?
I dont understand what should I write for ‘/my-service’ and where exactly do I see it in the console
[EDIT] one more thing I would like to ask is is there a requirement.txt size limit?
The koyeb deploy command allows you to directly push code from your local environment to Koyeb.
The Koyeb CLI bundles the contents of your directory and uploads it to Koyeb. On koyeb, we take care of the build either using Buildpack or Dockerfile depending on your settings.
When you use the koyeb deploy command, we create the app and the service if they do not exist. For instance, if you use koyeb deploy . Youtube/my-service while the app and the service don’t exist, we will create an app called Youtube, and create a service called my-service inside this app.
You will see apps and services on the overview and service pages in the control panel.
[Update] Got discouraged after using the cli for the first time. Got the following error:
koyeb deploy . x-app/x-service --archive-buildpack-build-command “pip install -r requirements.txt”
INFO[0001] Application x-app does not exist. Creating it
INFO[0002] Creating and uploading an archive from . Error while requesting an upload URL to upload the archive ‘.’ (58562847 bytes): the Koyeb API returned an error 400: Validation error
Additional details
Field size: size must be less than or equal to 50MB
How to solve the issue?
Fix the request, and try again
[INFO] Running custom build command: 'pip3 install -r requirements.txt'
bash: pip3: command not found
ERROR: failed to build: exit status 127
exit status 51
[Update] As of this koyeb post I dont need to write pip install as build pack automatically detects it so I removed and deployed again but I got the below error
It seems that it still tries to use the cusotom build command. Could you delete your service and create a new one without passing --archive-buildpack-build-command
ERROR: no command to run your application: add a run command in your Service configuration or create a Procfile in your archive. Check How We Build from Git | Koyeb for more details.
Application exited with code 1. This usually indicates an application failure. Check that the command used to launch your application is correct.
ok, so it seems you need to provide custom run command: --archive-buildpack-run-command The command which you use to start your app. I guess python <something>
I am unable to perform the solution because I am having little account issue I sent you a message could you look into it. Only then I can update this post with if the solution worked
I can not express in words how happy I am right now. it worked, I was able to deploy my project directory perfectly without any issue. Thank you @Lukasz_Oles and Thank you @David for helping me navigate through the issues because these constant errors were really breaking my morale
