I was trying the ubuntu ssh server. My service and deployment is healthy but I am not seeing the address to which I can ssh into.
Help
Help
Hi there,
We have identified the issue and are working on a fix right now.
Sorry for the inconvenience.
Hi again,
The issue should be fixed. The port will be assigned when the service wakes up if it is sleeping, or if you redeploy the service.
We are also working on patching the logic to also assign ports to sleeping services.
Thank you for your patience
@Alexis_Guerville Thanks, I will give it a try!
Also regarding sleeping services, if the machine sleeps and is again waken up, does the data on the ephemeral disk remain or what?
No the service will not keep data after sleeping and waking up.
If you want data persitency, I suggest using a volume.
