I’m trying to get a Spring Boot Application with Gradle running on koyeb.
I want to deploy this GitHub repo: GitHub - tschuehly/fullstack-with-spring: Demo repository for my talks focusing on server-side-rendering with Spring ViewComponent and HTMX
I’ve set the buildpack run command to ./gradlew bootRun and it tries to start but it doesn’t complete starting.
Here’s the log:
Instance allocated in nomad
Service mesh is propagated
Instance is starting
Picked up JAVA_TOOL_OPTIONS: -Dfile.encoding=UTF-8
Starting a Gradle Daemon, 1 incompatible and 1 stopped Daemons could not be reused, use --status for details
> Task :checkKotlinGradlePluginConfigurationErrors
> Task :compileKotlin UP-TO-DATE
> Task :compileJava NO-SOURCE
> Task :processResources UP-TO-DATE
> Task :classes UP-TO-DATE
> Task :resolveMainClassName UP-TO-DATE
> Task :bootRun
. ____ _ __ _ _
/\\ / ___'_ __ _ _(_)_ __ __ _ \ \ \ \
( ( )\___ | '_ | '_| | '_ \/ _` | \ \ \ \
\\/ ___)| |_)| | | | | || (_| | ) ) ) )
' |____| .__|_| |_|_| |_\__, | / / / /
=========|_|==============|___/=/_/_/_/
:: Spring Boot :: (v3.2.2)
2024-03-02T18:01:58.180Z INFO 94 --- [ restartedMain] d.t.f.SpringFullstackDemoApplicationKt : Starting SpringFullstackDemoApplicationKt using Java 17.0.9 with PID 94 (/workspace/build/classes/kotlin/main started by koyeb in /workspace)
2024-03-02T18:01:58.196Z INFO 94 --- [ restartedMain] d.t.f.SpringFullstackDemoApplicationKt : No active profile set, falling back to 1 default profile: "default"
2024-03-02T18:01:58.456Z INFO 94 --- [ restartedMain] .e.DevToolsPropertyDefaultsPostProcessor : Devtools property defaults active! Set 'spring.devtools.add-properties' to 'false' to disable
2024-03-02T18:01:58.460Z INFO 94 --- [ restartedMain] .e.DevToolsPropertyDefaultsPostProcessor : For additional web related logging consider setting the 'logging.level.web' property to 'DEBUG'
Instance is stopping
The message received from the daemon indicates that the daemon has disappeared.
Build request sent: Build{id=d29216f4-1441-495e-88a0-5197e1a2ce7f, currentDir=/workspace}
Attempting to read last messages from the daemon log...
Daemon pid: 37
log file: /layers/heroku_gradle/home/daemon/8.5/daemon-37.out.log
----- Last 20 lines from daemon log file - daemon-37.out.log -----
2024-03-02T18:01:32.354+0000 [INFO] [org.gradle.launcher.daemon.server.exec.LogToClient] The client will now receive all logging from the daemon (pid: 37). The daemon log file: /layers/heroku_gradle/home/daemon/8.5/daemon-37.out.log
2024-03-02T18:01:32.357+0000 [INFO] [org.gradle.launcher.daemon.server.exec.LogAndCheckHealth] Starting build in new daemon [memory: 494.9 MiB]
2024-03-02T18:01:32.367+0000 [DEBUG] [org.gradle.launcher.daemon.server.exec.ExecuteBuild] The daemon has started executing the build.
2024-03-02T18:01:32.367+0000 [DEBUG] [org.gradle.launcher.daemon.server.exec.ExecuteBuild] Executing build with daemon context: DefaultDaemonContext[uid=c7fcfeae-063e-46a2-83c2-503d63990005,javaHome=/layers/heroku_jvm/openjdk,daemonRegistryDir=/layers/heroku_gradle/home/daemon,pid=37,idleTimeout=10800000,priority=NORMAL,applyInstrumentationAgent=true,daemonOpts=--add-opens=java.base/java.util=ALL-UNNAMED,--add-opens=java.base/java.lang=ALL-UNNAMED,--add-opens=java.base/java.lang.invoke=ALL-UNNAMED,--add-opens=java.prefs/java.util.prefs=ALL-UNNAMED,--add-opens=java.base/java.nio.charset=ALL-UNNAMED,--add-opens=java.base/java.net=ALL-UNNAMED,--add-opens=java.base/java.util.concurrent.atomic=ALL-UNNAMED,-XX:MaxMetaspaceSize=384m,-XX:+HeapDumpOnOutOfMemoryError,-Xms256m,-Xmx512m,-Dfile.encoding=UTF-8,-Duser.country=US,-Duser.language=en,-Duser.variant]
2024-03-02T18:01:32.369+0000 [INFO] [org.gradle.launcher.daemon.server.exec.ForwardClientInput] Closing daemon's stdin at end of input.
2024-03-02T18:01:32.372+0000 [INFO] [org.gradle.launcher.daemon.server.exec.ForwardClientInput] The daemon will no longer process any standard input.
. ____ _ __ _ _
Instance terminated in nomad
