I’ve tested the build on my local machine using pack cli and it is able to build and deploy to local docker without error. However, it is throwing error on koyeb
! Failed to execute build script.
11:43:22 AM stderr !
11:43:22 AM stderr ! The Heroku Node.js npm Install Buildpack allows customization of the build process by executing the following scripts if they are defined in package.json:
11:43:22 AM stderr ! - heroku-prebuild
11:43:22 AM stderr ! - heroku-build or build
11:43:22 AM stderr ! - heroku-postbuild
11:43:22 AM stderr ! An unexpected error occurred while executing npm run build. See the log output above for more information.
11:43:22 AM stderr ! Ensure that this command runs locally without error and retry your build.
11:43:22 AM stderr
11:43:22 AM stderr ERROR: failed to build: exit status 1
11:43:22 AM stderr exit status 51
