Nest.js and Prisma error connecting external database
Hello, I’m migrating an application from heroku.
However, when trying to connect to an external database, it generates the error:
PrismaClientInitializationError: Can't reach database server at `35.xxx.xxx.xxx`:`1433`
Please make sure your database server is running at `35.xxx.xxx.xxx`:`1433`
    at r (/workspace/node_modules/@prisma/client/runtime/library.js:105:2574)
    at async Proxy.onModuleInit (/workspace/dist/prisma/prisma.service.js:19:9)
    at async Promise.all (index 0)
    at async callModuleInitHook (/workspace/node_modules/@nestjs/core/hooks/on-module-init.hook.js:43:5)
    at async NestApplication.callInitHook (/workspace/node_modules/@nestjs/core/nest-application-context.js:224:13)
    at async NestApplication.init (/workspace/node_modules/@nestjs/core/nest-application.js:98:9)
    at async NestApplication.listen (/workspace/node_modules/@nestjs/core/nest-application.js:168:33)
    at async bootstrap (/workspace/dist/main.js:21:5) {
  clientVersion: '4.14.0',
  errorCode: 'P1001'
Hi Jose,
Can you let me know if you have IP restrictions configured to access your database? That could explain why you are not able to connect from Koyeb.
Thanks
this is true, I just checked this.
