I created my first web service and its stuck at provisioning
Hi @Anil_Karaniya ,
You hit a bug!
(that we are going to fix right away)
But you did so using the wrong environment variable syntax ${{ something.SOMETHING_OTHER }}.
The docs suggest how to use them. Either set a value, or use the {{ OTHER_VAR }} syntax to interpolate other variables, or the special syntax {{ secret.SECRET_NAME }} to refer to and interpolate from a secret when defining an environment variable.
Cheers
It seems to happen even if you delete a secret env, but you still have it referenced in the service envs.
