My deployment is failing today after stucking at Starting for some time (No Logs Showing)
My deployment is failing (today) after stucking at Starting for some time. When I check Build logs, it is successfully completed. But there is no logs for Runtime and it is just loading for a long time before it eventually fails. My app docker configuration is correct and I have been deploying it successfully up to today.
Please help. I cannot still deploy successfully.
same problem,
Hi!
Thank you for reporting this issue. Due to an unexpected load, the Washington region ran out of capacity before we managed to deploy additional machines. The issue is now resolved and your deployments were completed. If your deployment did not proceed automatically, you can trigger it manually by clicking the Redeploy button. Apologies for the inconvenience!
Thank you. It is working now.
