Multiline secret, how to do it?
When you bulk edit environment vars, you can use quotes to set a value that spans multiple lines, like this:
PUBLIC_KEY=“-----BEGIN PGP PUBLIC KEY BLOCK-----
Comment: ABAF 11C6 5A29 70B1 30AB E3C4 79BE 3E43 0041 1886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=HpqG
-----END PGP PUBLIC KEY BLOCK-----”
How do you do this with a secret? I’ve tried pasting in the key (without the quotes) using the Secrets GUI, but my application sees the key with \n replaced with spaces.
Hi,
Creating multiline secrets isn’t supported by the control panel, but it would make sense to allow it. Feel free to open a feature request!
As a workaround, you can call our API directly with curl (grab a token from your organization’s settings).
TOKEN=''
curl 'https://app.koyeb.com/v1/secrets' -H "authorization: Bearer $TOKEN" -H 'content-type: application/json' --data '{"type":"SIMPLE","name":"name","value":"multiline\nstring"}'
Hi Scott, you can also rely on our CLI.
koyeb secret create public_key_secret --type simple --value "-----BEGIN PGP PUBLIC KEY BLOCK-----
=HpqG
-----END PGP PUBLIC KEY BLOCK-----"
Could be nice to add this feature in the UI. That’d simplify people life when starting with Koyeb and settings up a new app
Hi! Creating multiline secrets is now possible through the Koyeb control panel :slight_smile:
