Minio instance does not start
Hi
I try to run a click-application in order to deploy Minio.
The instance doesn’t start with this message.
Instance created. Preparing to start…
Application exited with code 1. This usually indicates an application failure. Check that the command used to launch your application is correct.
Instance is starting… Waiting for health checks to pass.
Incorrect Usage: flag provided but not defined: -console-adress
Instance stopped.
Instance stopped.
My app name is advanced-dody
thank you
I’m seeing the same thing
just found it was trhe starting command missing a “d” in “address”.
i fixed it and redeploy and it worked
