I tried deploying the app and it was failed. Attached logs.
Starting download for registry01.prod.koyeb.com/k-65239143-3a1f-4b6b-9ae0-7ab6370194a2/b38b0b08-c626-44cb-889c-6fd37dbb8a19:932ac968-3545-4771-801c-370fad316b7d
Download progress: 59% |e[32m++++e[0m----| (20.0 MiB/s)
Download progress: 59% |e[32m++++e[0m----| (9.6 MiB/s)
Download complete for registry01.prod.koyeb.com/k-65239143-3a1f-4b6b-9ae0-7ab6370194a2/b38b0b08-c626-44cb-889c-6fd37dbb8a19:932ac968-3545-4771-801c-370fad316b7d
Application exited with code 1. This usually indicates an application failure. Check that the command used to launch your application is correct.
ERROR: no command to run your application: add a run command in your Service configuration or create a Procfile in your git repository. Check https://koyeb.com/e/run-command for more details.
Instance is starting... Waiting for health checks to pass.
Instance stopped.
Download progress: 66% |e[32m+++++e[0m---| (22.6 MiB/s)
Download progress: 66% |e[32m+++++e[0m---| (10.9 MiB/s)
Instance stopped.
