Hi,
I’m trying to deploy this app, which is a Realtime AI using LiveKit for WebRTC connections.
The agent fails to connect to LiveKit server’s URL:
wss://<my_instance>.livekit.cloud
Not much in the agent log:
# more /var/log/supervisor/agent_stderr.log
2024-12-16 10:40:28,039 - DEBUG asyncio - Using selector: EpollSelector
2024-12-16 10:40:28,047 - DEV livekit.agents - Watching /app
2024-12-16 10:40:30,420 - DEBUG asyncio - Using selector: EpollSelector
2024-12-16 10:40:30,426 - INFO livekit.agents - starting worker {"version": "0.12.2", "rtc-version": "0.18.2"}
2024-12-16 10:40:30,472 - INFO livekit.agents - registered worker {"id": "AW_w9QCf8CArTPr", "region": "Germany", "protocol": 15, "node_id": "NC_DFR
A1A_g3PnXGhfWwXt"}
2024-12-16 10:42:54,286 - INFO livekit.agents - received job request {"job_id": "AJ_RmDvEJNGbe8C", "dispatch_id": "", "room_name": "ricoapp-2412161
042-anon-f2b3d", "agent_name": "", "resuming": false}
2024-12-16 10:43:04,313 - ERROR livekit.agents - initialization timed out, killing process {"pid": 41}
Is there any restriction to connect from the Koyeb instance to a remote service in using wss protocole?
(I’m using the free plan)
Thanks for your help,
Xavier
