Please help me fix this issue i have attached my deploy log below ![]()
Instance allocated in nomad
Instance is starting
Instance is unhealthy
Instance terminated in nomad
/workspace/bot.py:47: DeprecationWarning: There is no current event loop
Initalizing MartinBot
No additional clients found, using default client
MartinBot Imported => connection
MartinBot Imported => route
MartinBot Imported => genlink
MartinBot Imported => broadcast
MartinBot Imported => p_ttishow
MartinBot Imported => commands
MartinBot Imported => gfilters
MartinBot Imported => pmfilter
MartinBot Imported => channel
MartinBot Imported => filters
MartinBot Imported => index
MartinBot Imported => init
MartinBot Imported => inline
MartinBot Imported => banned
MartinBot Imported => Premium
MartinBot Imported => join_req
MartinBot Imported => misc
MartinBot Imported => files_delete
07:22:33 AM - 78 - root - bot - INFO - ᎷᎪᎡͲᏆΝ Ꮩ2 with for Pyrogram v2.0.106 (Layer 158) started on Martin444_12_bot.
07:22:33 AM - 79 - root - bot - INFO - Current Cusomized Configurations are:-
IMBD Results are disabled.
P_TTI_SHOW_OFF is disabled files will be send in PM, instead of sending start.
SINGLE_BUTTON is Found, filename and files size will be shown in a single button instead of two separate buttons
CUSTOM_FILE_CAPTION enabled with value
Fɪʟᴇɴᴀᴍᴇ: @moviez_areas {file_caption}
Size: {file_size}, your files will be send along with this customized caption.
LONG_IMDB_DESCRIPTION is disabled , Plot will be shorter.
Spell Check Mode Is Enabled, bot will be suggesting related movies if movie not found
Full List of casts and crew will be shown in imdb template, restrict them by adding a value to MAX_LIST_ELM
Your current IMDB template is
ʜᴇʏ {message.from_user.mention}, ʜᴇʀᴇ ɪꜱ ᴛʜᴇ ʀᴇꜱᴜʟᴛꜱ ꜰᴏʀ ʏᴏᴜʀ ǫᴜᴇʀʏ {search}.
{title}
{rating} |
{runtime} Minutes
{release_date}
{director}
● {languages}
● {genres}
{plot}
ᴘᴏᴡᴇʀᴇᴅ ʙʏ : {message.chat.title}
07:22:33 AM - 80 - root - bot - INFO -
BOT WORKING PROPERLY
Instance is stopping
