I had to change a very simple line that returns a value from a route, and now that I tried to deploy, I’m getting an error related to Rust.
Could someone help me?
Deployment ID: 8359f2fb-64d7-4010-b737-70d9e6c1e124
Hi!
Did you change dependencies?
Hello @marcelo_diefenbach,
From what I see, your current deployment runs on python 3.12. The new, failing, deployment is using python 3.13. If you want to keep the older version, create .python-version file with the following content:
3.12.7
You can read more about it here.
This should fix the issue.
Why does it happen? I’m not sure. It seems that in python3.13, for some reason, pip cannot download a binary for the rust-based package pydantic_core and tries to build it and fails.
