Erroring in previous deployment, current deployment run more than 10 minutes
Hi,
My previous deployment stuck on “Erroring” and my current deployment run more than 10 minutes. Can you check on you side if there is issue? My service in Python.
Thank you
same error here, a service in python too
Same! Streamlit app via docker!
Same with me as well! Tried several times! No luck, I use django + buildpacks + postgres.
We have faced an issue on our platform affecting the free instances.
I check and all your services seems up and running.
@Tiago_Alves can you try to redeploy your service? It should successfully deploy the last version of your service.
Thank you all!
Thank you. I tried to deploy again and I face same problem - “Erroring”… eventually it failed.
I’m having the same problem. It was stuck with “Erroring”.
Then I tried to redeploy but the deploy was stuck too.
I tried to delete the service to retry with a new one and stuck in deleting the service.
Don’t know what to do now :frowning:
I was experimenting this platform to see if it’s good for other projects but this was my first experience with it :frowning:
