Failing to Upgrade to Starter Plan
Hi, I’m trying to upgrade to starter plan, I added my payment method but getting a screen with 500 Error.
I really wanted to try out koyeb, would appreciate if this can be resolved.
Thanks.
It’s similar to this issue where your default payment method is defined to use “Link”.
Could you go to the Stripe customer portal (I think it’s called manage billing on our control panel) to remove it and use a credit card as default payment method?
Thank you very much.
