Fail to build for the first time
Error from logs:
Instance is starting... Waiting for health checks to pass.
TCP health check failed on port 8000.
Instance stopped.
How I can debug that?
App works great locally and on Vultr. All local vars are there. Runtime.txt is there.
Run command that I set in settings: python3 main.py
Hi @Art, does your app listen on port 8000?
@Lukasz_Oles Super helpful, thanks.
Next boss: I use auth via terminal and have to put credentials via CLI, otherwise it can’t be launched. Web UI gives only logs, not console. I installed CLI.
Ok, now:
koyeb service redeploy foo/bar
INFO[0002] Service foo/bar redeployed.
Nothing happened, I don’t see the same logs and prompt to input credentials (as I see from web UI).
Thanks for the help
What credentials do you mean? I see that CLI worked, so not Koyeb credentials.
Pyrogram’s auth is one-time procedure via console.
Server started at: 2025-02-04 09:29:46.461699
Welcome to Pyrogram (version 2.0.100)
Pyrogram is free software and comes with ABSOLUTELY NO WARRANTY. Licensed
under the terms of the GNU Lesser General Public License v3.0 (LGPL-3.0).
Enter phone number or bot token: Server started at: 2025-02-04 09:30:59.685611
