I keep receiving the following message during deployment: ‘Service degraded. The latest deployment […] did not complete successfully. The service continues to operate with the active deployment […].’ The deployment starts, takes about 15-20 seconds, then fails without showing a specific error in the logs. I experienced something similar last Friday, but everything worked fine on Saturday. However, today I’m consistently getting errors.
Hey,
Sorry for the inconvenience. It looks like your workload hit a weird bug related to autoscaling. We will probably be able to ship a fix tomorrow.
In the meantime, you may temporarily disable autoscaling. It should allow your next deployment to get through
Hey,
The fix has been deployed. You may re-enabled autoscaling whenever needed.
Thank you for your help and fast fixing)
