Docker pull rate limit when deploy a container
We cannot deploy a service using docker. This is the error log from koyeb:
Dockerfile:1
03:52:00 PM stdout --------------------
03:52:00 PM stdout 1 | >>> FROM python:3.11-buster AS builder
03:52:00 PM stdout 2 |
03:52:00 PM stdout 3 | RUN pip install poetry
03:52:00 PM stdout error: failed to solve: python:3.11-buster: failed to resolve source metadata for Docker Hub Container Image Library | App Containerization failed to copy: httpReadSeeker: failed open: unexpected status code https://registry-1.docker.io/v2/library/python/manifests/sha256:3a19b4d6ce4402d11bb19aa11416e4a262a60a57707a5cda5787a81285df2666: 429 Too Many Requests - Server message: toomanyrequests: You have reached your pull rate limit. You may increase the limit by authenticating and upgrading
Could you please help, my sistem is impacted
I think this was a temporarily error, after 30 minutes, the error disappeared
Sorry for the inconvenience.
We addressed this issue. That is why you do not see it anymore.
This is happening again, @David - can you check please?
Yes, please check again.
P.S. two hours already passed, no response.
Seems to be working now, my container was built and deployed successfully.
