Deployment stuck in “Getting ready / Provisioning” with no build logs (build never starts)
Hi everyone,
I’m experiencing an issue where my deployment gets stuck indefinitely in the “Getting ready / Provisioning” state.
Key details:
  • The build never actually starts
  • No build logs are generated at all
  • The deployment remains in Provisioning and shows “Deployment: Not started”
  • I’ve tried multiple forced rebuilds
  • I’ve verified configuration (start script, port, package.json, env vars)
  • The behavior is exactly the same every time
Normally, during provisioning, I would expect to see build activity such as repository cloning or buildpack detection. In this case, none of that happens — it stays stuck before any build step begins.
This strongly suggests a build infrastructure / builder availability issue rather than an application or configuration problem on my side.
Has anyone experienced something similar recently, or is there a known issue with the build infrastructure (possibly region-specific)?
Thanks in advance for any insight.
Hi @Dangelo_Magno_Dias_A
From what I see, all your services in both orgs are running ok now. When did it happen?
Hello Lucas, everything is working very well now. I believe the issue was temporary.
TKS!
Merry Christmas!
