My Deployment is stuck at provisioning
My deployments get stuck at provisioning (pending) for a really long time.
Hi @Chinmay_Joshi ,
We resolved the issues with the deployments taking long time to provision after build succeeded and you should not face it anymore.
Hey @Chinmay_Joshi ,
My Deployment is also stuck in provision stage for a really long time.
Please help me too Sir.
Facing the same problem again
I didn’t change anything from my side, looks like you’ll have to get help from support directly.
Hi @Chinmay_Joshi ,
We resolved the issue which was causing this prolonged provisioning so it should be no longer a problem.
Hi @Chinmay_Joshi ,
Having same issue again, the build phase will be done, but deployment won’t go from Building to Runtime, unless I cancel it and re-deploy
Hi, I’m having the same issue, my deployment has been stuck on provisioning for a while now
