Deployment failure on TT N300
I have been trying to deploy some models on N300. Most often than not I keep getting Internal deployment error. Something like 24 times out of 25 tries this error log appears.
I can confirm this. The issue has been around for over a month.
There usually are no logs whatsoever, the instance just never leaves “starting” state, which makes it impossible to debug.
Hey, I wanted to mention that when you often get internal deployment errors with a TT device, it may help to pause the entire service and then resume it again once the active deployments shows status “stopped” (may take a while). Often helps in my experience.
Hi, thanks for the suggestion. Do you pause it briefly, or do you give it some time?
Briefly works fine for me. As soon as it shows the “resume” button you can resume it.
