I am getting the error “deep sleep is not enabled for this plan” when i try to deploy a web service.
Out of nowhere this warning has been stated showing during deployment And also its not letting deploy any services. No explaination at all.
Hey sorry for inconvenience, we got faulty validation of deep sleep config for hobby plan. It should be fixed now:)
It has been fixed for new deployments but when i edit the deployment settings then redeploy the same message is showing.
No. It has not been fixed yet. Not even for new deployments
Hi, experiencing the same issue. At times, it is allowing me, but most of the time it says “deep sleep is not enabled for this plan”
Apologize! It should be fixed for all now. It seems like we’re still hitting some validation edge case in some scenarios.
