Deployment scales to zero but won't wake up
I have a simple node.js deployment set to scale from one to zero. It successfully scales to zero but when I try to load the slash page I get the Koyeb “your service is almost ready” message but the service sleeps forever.
Scaling to zero works. Does scaling back from zero work?
Can you confirm you are talking about the metronome service?
Yes, it works. We need to investigate why it did not work for your service.
Could you try to enable scale to zero again and verify if the issue persists?
Hi David, Yes it is the metronome service. Thank you for this.
Actually none of my services work right now. For the last day or so they have been getting “Could not retrieve one or more Secrets”.
Did I break something? Not sure how. Even the Koyeb github examples down deploy. Looks like I don’t have permission to download the built services for some reason.
I mean “Even the Koyeb github examples don’t deploy.”.
This should be fixed. Can you try again?
Thank you for getting everything going. But why did I get locked out for 40 hrs or so? If I had been in production already that would have been bad.
Hi @Kyle_Howland-Rose,
The issue preventing the service from waking up should be fixed.
Regarding the issue that was preventing proper deployment, you were not locked out, but you were facing an internal error that was fixed as well.
