Consistent Deployment Error
Hi team,
A few weeks ago I started using Koyeb but because of some issues on my side I wasn’t able to upgrade my account in time. Because of that I think my services were deleted. No problem with that.
However after paying everything, I’m trying now to deploy again my customer’s application, I’m consistently getting the following error:
I’ve tried using the build process (as the screenshot above shows) as well as using my private image registry. Both give me the same error that I didn’t have on my first try when I was on trial. I really need to get this solved because the application needs to get deployed so that the customer can start using it. Also worth to note that I do have that same application deployed in another provider (render.com, from which I was planning to migrate from) and I’ve tested deploying the same application as is and it works there with no issues.
I really appreciate any insight you can provide.
HI @Patrick_Mazulo
I see that you are trying to mount your volume as a root directory / Currently we do not support such configuration.
Do you want to boot from volume or is it a mistake in configuration?
Regards
Hi @Lukasz_Oles
I see, actually I wasn’t aware of that. I think I might have forgotten what was the mounting point I’ve used the last time. Let me give it a shot by changing this and seeing how it goes.
That was it, thanks!
